-   -   Trans (https://www.onlycubcadets.net/forum/showthread.php?t=6174)
ljones 09-01-2010 05:45 PM
Trans
My 122 has a vibrating sound coming from the trans when you roll it. If you adjust the brake out far enough it will stop, but you have no brake. If you adjust it to where it brakes it make a vibrating sound and has some friction when you roll it. What is wrong ?
darkminion_17 09-01-2010 10:10 PM
Lucas
Sounds like your internal brake is seized
Remove the brake rod.
Remove the brake lever.
Spray some PB blaster in there.
Remove the brake rod push lever.
If you can remove the little round ball that is in there,I use a magnetic pickup tool,you almost got it.
Do not lose the ball.
Spray more pb blaster in there and it may loosen it up the brake puc.
Put it all back together and try it out.
You may have to do this a few times.
Good luck!!!!
Yosemite Sam 09-01-2010 10:14 PM
Is this a "vibrating sound" or is it a vibration?
How are you sure it is the transaxle that has the problem?
ljones 09-02-2010 07:50 AM
Both I know it is the brake becaus I can adjust the brake to where it stop making the sound.
ljones 09-02-2010 09:47 PM
3 Attachment(s)
I made some progress tonight got the linkage out but I cant get the littel ball out I have been shooting the hole full of pb.
Here are some pics.
Merk 09-02-2010 10:09 PM
I suggest you get a repair manual if you don't have one. There is more to it than just getting the ball out. The trans has to come out. The reduction housing has to come off.
What has happen the o-ring has dirt around it and has dried out/harden/swelled up enough so the brake lining retainer doesn't move anymore. The o-ring needs replaced.
Check out page 2 of this topic:
http://www.onlycubcadets.net/forum/s...le+Dick&page=2
It shows what you have to do to replace that o-ring. You need a reapir manual because some of the bolts have torque reading they need to be.
darkminion_17 09-02-2010 10:18 PM
Yeah Dale,
I was kinda leaning towards that but you gotta try the easy stuff first.:biggrin2.gif:
Lucas do you really need a brake??:bigthink:
ljones 09-03-2010 07:56 AM
I have a manual.
YES I need a brake.
Is it possible to do this witout draining the trans fluid ?
Matt G. 09-03-2010 08:32 AM
Yes, if you remove the transaxle and tip it up on end.
ljones 09-03-2010 04:46 PM
Trans axel ?
