-   -   Bolt (https://www.onlycubcadets.net/forum/showthread.php?t=61766)
Mr Bob 12-03-2023 05:41 PM
Bolt
Can some tell me the name of the bolt that is used to hold the spindle on to the deck on the old decks. The head is flat and they have grooves around the bolt that will hold the bolt from turning as you put a nut on it. Thanks for any help in advance. Have a great night.
Bob
finsruskw 12-03-2023 05:53 PM
They are called carriage bolts
IHinIN 12-03-2023 08:16 PM
The flat head bolts with the square under the head are called “plow share bolts”.
Carriage bolts have a larger domed head.
Mr Bob 12-03-2023 08:22 PM
Bolt
The bolts I am talking about have like splines under a slit curved head.
Bob
darkminion_17 12-03-2023 09:07 PM
Cast iron spindles?
athomas 12-03-2023 09:23 PM
https://www.mcmaster.com/products/plow-bolts/
Steve N Mi 12-03-2023 09:40 PM
Ribbed Elevator Bolts
https://www.mcmaster.com/products/bo...ibbed/?s=bolts
If this is not what you want look around www.mcmaster.com they offer a huge selection of bolts and screws. Prime fasteners has a great selection as well.
Ozcub 12-04-2023 12:05 AM
Bob
I think you may have to post a photo
Oz
ol'George 12-04-2023 07:29 AM
Sounds like he is describing a bolt like a lug stud on a hub or Axle that holds the wheel on.
Those a have spline sort of under the bolt head.
The head cam be somewhat flat like a plow bolt or domed like a carriage bolt.
Yes please post a pix so we can help further, as OZ suggested.:beerchug:
ironman 12-04-2023 07:53 AM
2 Attachment(s)
They are the square neck flat head plow bolts as athomas posted the link to up above.
You need the flat heads because the pulleys, specifically the center pulley, sit down so close to the top of the spindle housing that they would rub anything sticking up too high.
