1650 Driveshaft ball bearings
Trying to find information on how the 1650 driveshaft is installed. I have a late build with the twin flexible couplers in the rear. No ball bearing in the rear however it does have the ball bushing in the rear metal coupler My question is on the front coupler to the engine. The flange also contains a ball bushing but is there supposed to be a ball bearing as well? And if so what is the correct order for assembly. I've looked at the schematic and I don't see a ball bearing but I've seen it mentioned in other threads but believe they are referring to the bushing.
Thanks! |
Here's the link to the driveshaft and ball bearing coupler.
Used on the driveshaft replacement for ser #'s 622951 and below. The ball keeps the d/s centered on the o input shaft of the hydro. Only one req'd and it is on the rear https://www.cubcadet.com/en_US/conte...781bcb9734d0/y |
| All times are GMT -4. The time now is 12:23 AM. |
