-   -   1641 steering gear (https://www.onlycubcadets.net/forum/showthread.php?t=62269)
bean1974 05-25-2024 07:31 PM
1641 steering gear
i have 10 in of freeplay left and right.any fixes available
:beatdeadhorse: tks guys
darkminion_17 05-26-2024 09:40 AM
10" is a lot, you may have a broken steering shaft.
bean1974 05-26-2024 01:05 PM
1641 steering gear
i mow my yard my arms a like jello when im done
bean1974 05-26-2024 05:37 PM
steering gear
it still turns right and left but at least 8 in of free play
johnwd98 05-27-2024 08:14 AM
you're not providing enough info to get any help. You may have to get on your hands and knees and wiggle the steering wheel back and forth to find any obvious signs of wear. For starters, the sector may be worn and need adjustment or parts replaced, the drag link ends may be worn, the tie rod ends may be worn, the spindles may be worn, the pivot pin for the axle may be worn. You could also need to check toe-in, just to name a few.
Cannon51 05-27-2024 09:29 AM
If it is the column here's a thread in the Tech section that may help. I replaced the rod ends then bearings and pin in the gear box on my 1641 a few years ago. It made a big difference. https://www.onlycubcadets.net/forum/...ead.php?t=4631
Cannon
Sam Mac 05-27-2024 09:55 AM
Check your E-Mail, I sent you the service manual for the Cyclops series tractors and mower decks.:beerchug:
