-   -   105 Shaft (https://www.onlycubcadets.net/forum/showthread.php?t=6231)
mrcubcadet 09-05-2010 07:50 PM
105 Shaft
I have been hearing a little scratching/hitting in the fan area on my 105, so I got looking and two bolts holding the fan guard came out, so I replaced them. That stopped the scratching/hitting for awhile, but then yesterday it came back, and the bolts were tight. But I watched the drive shaft turn as I cranked it and it was bouncing around, so I checked the vibration disks and they were tight and looked fine. So then I checked the drive shaft, and it's bent. My question is, how could this have happened, and is there something else I need to replace besides the shaft?:bigthink:
Thanks
nuzzget 09-05-2010 08:01 PM
I'm not entirely sure. It could've just warped over time or a bolt for it might of came a little loose. Thats all i got. When you get a new one just make sure its all aligned.
mrcubcadet 09-05-2010 08:17 PM
Yes, I really don't know how it happened.:bash2:
nuzzget 09-06-2010 03:08 AM
Im just saying when i got my 127 it was bend a bit but how i noticed it it cause alot of vibration. The 127 also sat for a long time and such so i just assume it gets warpped over time.
mrcubcadet 09-06-2010 09:30 AM
Did you replace the shaft, or just straighten it?:bigthink:
nuzzget 09-06-2010 03:00 PM
Just replaced it. I don't know anything about straightening metal rods or anything.
mrcubcadet 09-06-2010 03:05 PM
I wonder if my dealer would carry new shafts?:bigthink:
_DX3_ 09-06-2010 03:20 PM
Made my own for my 1250. 5/8 round stock from your local hardware store.
mrcubcadet 09-14-2010 05:57 PM
Alright....I have found out that my shaft is not bent. The end that goes into the hydro's input shaft it worn. I have ordered a new flex disc (because I figured this probably wasn't good for it) but what should I do about this worn end?:bigthink:
Thanks
hydrocub 09-14-2010 06:38 PM
weld it up and file down .....or make / buy a new one . I welded mine .
