Replacing Rear Tire - Floor Jack Placement
Greetings!
Nice Forum here! I have a 2015 Cub Cadet XT-1 LT46 and I need to change the (flat) rear tire. I spoke with their Tech Support as to where to place the floor jack and was told to place it in the center of the box (transaxle?) where the two axles enter. He was adamant that I not under any circumstances use the Axle as a support point as it can bend. Any thoughts? Thanks, Lyman |
Best, Lyman |
Best, Lyman |
It's not wise to jack the back end up in the center because the front axle pivots in the center and once the rear wheels are off the ground the tractor will be unstable.
Sooooo......jack it |
I really appreacite the help! Lyman |
Pry off the black rubber hubcap, you will see a 9/16" bolt. Remove the bolt and slide the wheel off the axle. |
Best, Lyman |
| All times are GMT -4. The time now is 01:06 AM. |
