-   -   Modifying a plow mount for 1650 (https://www.onlycubcadets.net/forum/showthread.php?t=62708)
SDBOB 11-23-2024 09:58 AM
I picked up a plow mount and plow years ago.I got it out seeing if it will fit my 1650. Noticed the 2 round mounting tabs at front for quick disconnect. Now the question can I remove these 2 round tabs and put one long round pin in there place?
green407 11-23-2024 09:08 PM
I'm having trouble picturing what you're masking, some photo's would help.
SDBOB 11-23-2024 09:14 PM
I'm not experienced in posting photos.
green407 11-23-2024 09:19 PM
When you post a reply, there's a paper clip icon right of the smiley face icon, that will allow you to upload photo's.
SDBOB 11-24-2024 09:19 AM
Thank you I'll keep trying.
ironman 11-24-2024 10:58 AM
SDBOB, is this what you are talking about??
darkminion_17 11-24-2024 12:11 PM
I think the rod will hit the front axle pin.
finsruskw 11-24-2024 01:00 PM
And you want to do this because???
Those pins are firmly welded in there from the inside and will require some Butchering/grinding/drilling to get them out and for what gain?
Are you sure you don't have a narrow frame subframe like this?
SDBOB 11-24-2024 09:26 PM
Yes those are the tabs. I'll get picture Monday. I have a narrow frame 100 that I've used forever as a plow. This 1650 has front hydraulics. The frame I have (havent tried to mount it yet waiting for the cows to come home). The distance between the flat steel ears is about 10.25 inches from net it should work.
IHCubCadet147 11-25-2024 08:26 AM
This is what the correct subframe for a 1650 should look like…
