-   -   Mystery parts (https://www.onlycubcadets.net/forum/showthread.php?t=62790)
Reed Mitrowski 01-18-2025 09:34 PM
Mystery parts
So I had a box with random cub Parts in it. I know one piece was a snow plow mount that I need on my 782 plow setup. The other three pieces nobody seems to know what they are for. They have to be cub cadet as they were painted in the same paint as the snow plow mount. Anyone know what these are for or from? They could be for sale because I may not ever have a need for whatever they are. 716-353-2890. Thanks, Reed.
finsruskw 01-19-2025 09:58 AM
Are those solid pins or tubes?
What are the measurements and thickness of the angles that are welded on the ends?
Reed Mitrowski 01-19-2025 02:36 PM
Tubes, two holes in the end with the bolt
Farmall450 01-19-2025 08:35 PM
I thought they might go in a sleeve hitch, but there'd be a hole to pin them with a cotter pin somewhere then.
finsruskw 01-20-2025 09:13 AM
Maybe something someone has made up to hold a flag placed at the ends of the blade or something, who knows?
any holes at the ends of the blade where they may have been installed?
garydee 01-20-2025 09:38 AM
Or, maybe something that could be flipped up/down and secured horizontally with the second bolt to aid in picking up or maneuvering the blower into position. These units are very heavy, so some kind of handle might be a good idea if it had to be transported in a pickup truck or trailer. :biggrin2:
Ambush 01-20-2025 10:32 AM
Three is an odd number. Maybe missing one or you have a spare. :)
DeltaCub 01-20-2025 03:56 PM
Those are for the 154 and 185 Cub LoBoy. They are called guards or platform stops that are used when an IH deck is installed. They mount inside the frame near the rear of the engine.
darkminion_17 01-20-2025 05:10 PM
The queen has spoken, I thought they were the ones on a 3160 deck for a 284.
garydee 01-20-2025 07:31 PM
Part #13 in the picture shows the stop with one mounting hole. Reed's parts have 2 mounting holes. Were they made differently for the 154 and 185 LoBoys?
:bigthink:
