Cub Cadet 1042
Hi first post. I bought a 1042 late last year for a winter project, not running with wiring unattached in a field , I thought this will be a challenge to keep me busy all winter. got it home and realized, that the old Briggs 19.5 hp motor was not original, after i unstuck one exhaust valve and pulled off the fly wheel to see the shear key was wiped out and the timing was about 180 degrees out, i got it running, this carb has the fuel pump built right on to the carb, so after a fuel pump rebuild kit it runs and drives great the 42 inch deck was not attached at the time, so I engaged the electric pto switch and the pulley started up very quite and smoothly, I replaced two bearing on the port side spindle, mounted the deck started her up and pulled the pto switch and the deck started up with a very hard and sudden violent engagement that it lost rpm for a second or two, but ran smoothly and quietly, i found a on line manual and it said to engage the deck at top rpm, so that is what i did. Is there somewhere on the deck that i should be checking or is this normal and should be expected?
Thank you very much. |
Electric PTO's engage quickly and is normal.
While they say to start them at full RPM, longer life of all things related to the drive system denotes that a lower RPM is better. But if you have to increase the rpm's a bit keep the engine running, its just fine. I just don't like to hear a belt/pulley/clutch screech on start up. But the manufactures like selling replacement parts. :biggrin2: |
Reply to George.
Thanks for the tip I will try that. I took the deck drive belt off and spun all the bearings manually and none were stuck or even ruff to spin, I do question the angle of the furthest back pulley even though it is mounted to the deck with a very thick bracket, it sure has a very pronounced angle, sloping down towards the front, I have to take a look at another deck to see if that is correct, but the belt stays on, I wont know for sure until there is grass in 2 months.
Thanks again |
Pictures would make it easier to understand what you are describing,
thus easier to provide helpful suggestions. |
