-   Cub Cadet Rear Engine Rider & ZTR (RER) (https://www.onlycubcadets.net/forum/forumdisplay.php?f=43)
-   -   CC-30 H Forward and Reverse pedal has no resistance (https://www.onlycubcadets.net/forum/showthread.php?t=63314)
Gremilin 08-11-2025 01:46 PM
I have a CC-30 H Model #13A221JD010.
The forward and reverse pedal has no resistance. When sitting, with engine running, it falls to forward and takes off. I have called customer service a number of times with no help and I have also called 36 Cub service centers with no help. None of them can figure it out, I would think there would be maybe a spring or ball plunger to at least indicate neutral. We are all looking at the same diagram.
I would appreciate any and all help!
Thanks
ironman 08-11-2025 03:24 PM
I'm not familiar with your model but it looks like spring (#15) connects from frame
to that small hole in idler arm (#2). Spring may have broken or become disconnected.
That's where I'd start looking.
Gremilin 08-11-2025 05:22 PM
Thanks for the input the spring is in place I don't see where that has anything to do with the forward and reverse pedal assy
Attachment 117032
ironman 08-11-2025 06:45 PM
Just a guess, since it has the motion drive belt pulley's on the idler arm I figured it moves when you move the pedal and the spring would provide the tension.
But moving right along, here's another guess....
Check the return to neutral spring on your hydro, p/n 167.
Gremilin 08-11-2025 08:03 PM
Thanks again The spring is there and in the right place
Gremilin 08-12-2025 03:56 PM
I have a hard time believing that Cub can't solve this problem It shouldn't be this difficult
