-   -   PTO acting wonky (https://www.onlycubcadets.net/forum/showthread.php?t=63474)
Merkman 10-21-2025 01:35 PM
PTO acting wonky
2544 GT My PTO starting to act weird. It was engaged upon startup and would not disengage unless I lifted off the seat. When disengaged It would engage but not disengage! I cleaned the switch connection and cleaned the fuses
Any experience such behavior? Any ideas
Thanks
ironman 10-21-2025 02:28 PM
Please explain what you mean by "It was engaged upon startup".
Does that mean it was already engaged when you started the tractor, or it engaged itself when you started the tractor, or you engaged it after you started the tractor?
Merkman 10-21-2025 03:37 PM
Tractor started and blade was engaged with switch in.
Oak 10-21-2025 04:25 PM
You either have a wiring issue or bearings starting to fail in your PTO. Probably a wiring issue the way you explain it. Do you have a meter and know how to use it? Here is a wiring diagram of the 2544's but I'm not sure which year yours is.
https://www.ccpartsnmore.com/cub-cad...ing-schematics
Merkman 10-21-2025 04:31 PM
I do and I do, will track it down, thanks
Merkman 11-17-2025 10:02 AM
When I pull the 2 wire plug off from the pto, it remains engaged. Would I be correct in thinking I have a bearing seized in the clutch?
Sam Mac 11-17-2025 02:26 PM
You would be correct, you have a bearing that is done.
Merkman 11-17-2025 04:25 PM
Thank you Sam, is that a bearing that can be replaced or the unit itself gets replaced?
