How to angle a 54" blade
1st, I got a QA36A snowthrower!!! Pick it up Saturday. (Darn, I feel like a kid in a candy store!).
Now for my questions on the 54" blade: 1. Was there a kit to manually angle the blade? 2. If not, has an member made a gizmo to manually angle the blade? 3. Has an member made a hydraulic angling kit? Maybe using the hydraulic lift cylinder? The NOS and used kits are out of my price range for now anf winter's coming. Thanks for any and all help! :Cub7: |
The hydraulic lift cylinder is not strong enough IMO. If there's nothing to manually angle it, you must be missing some parts. It locks 15 and 30 degrees to each side.
CD:
Here is a link for the Operator's Manual......... 54 Manual The 42 & 54 inch front blades came from the factory for manual angle. You get off the tractor, pull up the locking tab and angle either way. YES, I have seen numerous home made Hydraulic Angle fabrications that work real well. |
I was afraid you were going to say get off and angle. My 71 Sears SS12 used ropes. Yeah, ropes. Guess I've have to grin and bear the cost of the angling kit.
Thanks guys. |
I looked long and hard for a cylinder to make one with. I never found an acceptable alternative. I broke down and just bought a kit.
Only thing I found, using my 54 blade with the hydraulic angle is you can only use it for snow. Using it even for loose dirt snaps the small mounting pin in the head. I've tried every type of bolt made, searching Mcmaster high and low, they all break. If somebody has an alternative please let me know. Usually I'll angle to where i want and drop the stock angle rod in to lock it in position. |
A 54' blade with X-trac front tires is the way to go. I had a 42' before and it was almost to narrow. With the 42' blade locked straight and plowing deep snow , the path it cleared (AFTER IT FALLS BACK IN) was barley wide enough for my 1211. Before I got the X-trac's The 54' blade would push the front with turf tires all around. Not any more.
AG tires are not designed to have good traction on slippery surfaces. I have tried to explain this before. It dose not matter if they are on rite or back wards. It is the tread design. Look at a good winter tire, not an all season or all terrain. They will have many grooves and sips. That is where the traction comes from. Plus most Ag tires are made from a hard compound, and that is not good for traction on slippery surfaces at all. Have you ever tried to drive a tractor with Ag's tires on the back on a slippery driveway or road ? No amount of weight is enough they still slide. Now put that same tractor and Ag's in deep snow and they it will go almost anywhere. But once the surface gets smooth and slick it is all over. |
You're first picture will actually help me prove my point. If you had one of you front wheels in you're hand and held it solid so it could not turn or spin. Would it be easier to slide it sideways, slide it forward ?
I agree there comes a point were the tire does not matter. But why people think that AG's are snow tires I will never understand. I have been plowing snow with trucks semi commercially for nearly 20 years. And I have tried to push more than the truck can control. As for the guy you saw in ( 4lock) that really does not matter. And in fact if the front wheels are spinning (no traction) they will slide easier than if they weren't. The reason 4x4 is good for plowing snow in a pick up is because when you raise the blade it takes all the weight off the rear wheels and you cant back out of the pile. There are plenty of plow trucks out there that are 2 wheel drive and do just fine, with enough weight in the back. Look at your township or city dump trucks, they are rear drive and pushing 10 plus feet wide. Your question of the sheet of ply wood is exactly my point. The ply wood is like the treads on your AG tires. Is it easier to walk into the wind with it full face or turned sideways ? So how much resistance do you think the AG's offer in a side load situation like said. I live just below Erie in the snow belt, so I get just as much if not more snow than most. I push it all with my 1211 and 54' blade. I use it at home because it give me some (me) time, and gives the truck a chance to thaw out. I clear about a 150 ft run with a 50x50 parking area at the end. I have no problems. |
Oh and the amount of weight per foot of plow the front of our tractors have is nowhere near the amount of weight per foot of plow a truck has. And I am pushing close to 11 feet wide with the wings out on my truck.
| All times are GMT -4. The time now is 09:07 PM. |
