-   -   Any Ideas?? PTO set screw stripped! (https://www.onlycubcadets.net/forum/showthread.php?t=6475)
Sminkey 09-18-2010 10:22 PM
Ok, getting my 71 ready for winter and when I bought it PO said he lost the pto, then called me 2 weeks later to tell me he found it. I was stoked, so I went to install it and one of the set screws is froze up and stripped out, should I just drill it out?, kinda of afraid to mess up the threads!
darkminion_17 09-18-2010 10:29 PM
Try forcing hehhehe a larger allen wrench on it an screw it in not out.
Sminkey 09-18-2010 10:35 PM
tried that...
Thanks, actually tried that one already and it's been soaking in PB for a few days now.
CMA's129 09-18-2010 11:09 PM
I got a stripped one out with a Torx bit. It was a long one with a hex end on it like you would use in a cordless drill, just beat it down in with a hammer and it came right out. If the PTO is already off mabey you should heat it after you get the bit drove down in.
johncub7172 09-18-2010 11:25 PM
No one ever forgets how important it is to have the dwell holes perfectly clean. It dont do no good to back a screw out of a hole smaller than the screw's self. That goes for both screws.
Yosemite Sam 09-18-2010 11:27 PM
Yup, #10 or #15 torx bit, might also try an impact driver.
johncub7172 09-18-2010 11:41 PM
1/8" cobalt drill bit
You will have to go realy slow and dont be stingy on the cutting fulid. You can follow up with a cobalt 3/16" drill bit to finish off the tip of the inner screw. Be careful you dont snap the bit at this point. I dont know however, if re-threading the pto is required after. I have not had to drill mine. Good luck!
Sminkey 09-18-2010 11:56 PM
Thanks guys!
Ya, will try a torx bit tomorrow! I always clean out/off the rust or crud from threads before I try to remove something, don't know why this set screw is stuck in there. May apply some heat to it, but will need to take it apart as to not burn the disc, which now that you guys got me thinking about it, I should rebuild completely as the PO rebuilt it(why it was lost) and I not sure of his ability after this set screw!!
Yosemite Sam 09-19-2010 12:09 AM
Did you try screwing it all the way through?
Sminkey 09-19-2010 12:19 AM
I will when I use a torx bit tomorrow, couldn't try that yet as it's pretty stripped out. Thanks
