Gas lines, Ect, Making your own parts
Has anyone ever bent there own gas lines??
I have a original that has a narly gas line! Id like to bend my own the steel ones. Has anyone bent there own wire bail for the bottom of the oil bath breather?? Is the wire "special" ? Im not only intrested in the above You all are welcome to post all your home made cub parts!! Any parts from hitches to panels!! Thanks Jason |
Since you are a HVAC Guy, I am sure you should have a Robinair Tubing Bender for copper tubing that would work just fine.
:ThumbsUp: |
Yes sir!!!!
I was doing a general search on the original and noticed they were copper not steel!!!So copper it is Jason |
Here's a quick fix. I bought a new cut to your length plug wire. (Ca-Ching). While putting on the POS connector that goes into the coil the little part that goes in the center, that makes contact with the wire broke.:bash2: I got the thinnest diameter shank carpet tack and attached the connector. The head of the tack makes excellent contact.:biggrin2.gif:
| All times are GMT -4. The time now is 04:11 AM. |
