-   -   1641 plow blade question (https://www.onlycubcadets.net/forum/showthread.php?t=6730)
tukn20s 10-08-2010 12:55 AM
Does anyone know if a front blade from a 1641 will fit a 682? its listed as a wideframe and looks similar to other wide frame plows I have seen, but the subframe is narrower. Thanks.
Matt G. 10-08-2010 09:45 AM
It will fit, but the geometry is messed up. The 1641 sits higher in the front because it has a different front axle, and the blade subframe is different as a result. You need an 82 series or WF blade.
