-   -   Oil Seal for Spindle (https://www.onlycubcadets.net/forum/showthread.php?t=7052)
Hubman 10-28-2010 11:55 AM
Thought I had on order for some oil seals $ 2.50 each order was canceled due to discontinued. Anyone know of a cheaper supplier of oil seal or cross reference no. for Napa then cub cadet . Oil seal 473428-R92 , Stens # was 240511 but seems discontinued . Thanks
cubs-n-bxrs 10-28-2010 12:05 PM
Just get the I.D., O.D. and the thickness of the seal and take the dimensions to napa and they should be able to set you up. I have had very good luck at my local napa. Nearest bearing and seal house is 35 miles from me so I always check napa first.
R Bedell 10-28-2010 12:05 PM
IH-473428-R92 is still available from Cub Cadet, This can be obtained from your local Cub Cadet or Case-IH dealers. It is also available from the Sponsors listed at the top of this page.
:IH Trusted Hand:
Hubman 10-28-2010 01:01 PM
I was hoping not to have to spend $6 - $8 a seal plus shipping . No local dealers by me. Thanks , I will get the dimensions of my seal and see if my local Napa dealer can hook me up . They sold me the bearings and cups , only $10 a set .
brjr51 10-28-2010 04:58 PM
I'm kinda in the same boat as you, Hubman. I'm rebuilding the spindles on my deck. My seals look brand new, still as pliable and snug on the spacers like a new one, but I'm hesitant to reuse something that old, and I'd hate to have to tear it apart again a couple years down the road just to save a couple bucks today.
Anyways, I cross referenced the seals to Chicago Rawhide, SKF #530484, but they're still just as pricey at my bearing joint as the IH Cub ones. Maybe your NAPA can cross to another brand.
Bob
Hubman 10-29-2010 11:17 AM
481u1111
Thanks for the information, My Napa dealer had trouble cross referencing he took the IH # and came up with a Napa # but the OD was wrong it was 1.756 instead of 1.781 or 1.785 . I find it hard to believe with a common bearing from Timken LM11949 and Cup LM11910 that the seal for this dimension is hard to find locally. But I am having trouble . I spent too much time bought from one of the sponsors added in some new blades to offset shipping cost on 2 seals. I wish I was not so impatient , every time I think I need a part I order only to find out 3 days later I need another part . I hate shipping charges. lol
Ash_129 10-30-2010 02:02 PM
I know you already ordered from a sponsor, but here is a link to another thread concerning oil seals from NAPA.
http://www.onlycubcadets.net/forum/s...ead.php?t=5570
Hubman 11-01-2010 08:46 AM
Ash , Thanks that will help in future . Napa # 10034 . I will run that buy the guys at my local Napa .
Edit ; Just checked that # 10034 online at Napa , it states thickness is .469" thick . the IH # is only .25 "thick does not look like a direct replacement. While the Chicago Rawhide # CR 530484 does look like the correct replacement . Found that at KSC Direct $5.07 each. but shipping was the same so bought from a sponsor.
Hubman 11-05-2010 03:53 PM
Bob
Bob, just got my parts from one of our sponsors the IH genuine part 473428-R92 actually is stamped CR 530484 on the oil seal . It looks like Cub Cadet is actually buying them fro Chicago Rawhide ( SKF )
