-   -   126 repair and rebuild question (https://www.onlycubcadets.net/forum/showthread.php?t=7289)
fathertrucker 11-14-2010 08:46 PM
bought a 126 with snow blower . further knowledge says i will not be happy with 3 speed trans. the tractor came with a hdyrotrans but plug was out of bottom seem to turn over but have no idea if okay. numbers on hydro are 406843 R91 /90-1030 /02-MB 20106 . can someone tell me if this hydro will fit in a 126 or where i can find out what year this came out of and if not okay inside is it feasible to fix? also found that snow blower gear box is stuck . parts for or are these a trouble area? how about adding creeper?
nickvanorman 11-14-2010 08:49 PM
i doubt that making a standard cub into a hydro would be very feasable. because, youd have to change out allot of things on the machine to make the hydro tranny work.
ACecil 11-14-2010 11:25 PM
If your 126 is equipped with a creeper, you'll be fine using the snowblower. As Nick stated earlier, I also wouldn't go through the hassle of putting the hydro tranny in the 126.
hillbilly 11-14-2010 11:43 PM
You could swap transmissions but it would be nice to have a donor tractor for the dash tower and linkage.
