1811/1812 hyd lines/hoses
Can some tell me if the hyd hoses from the hyd spool valve on an 1811/1812 do they rub against the fuel tank... cause mine do on my 1811 that I just put a dual spool valve on ... they do not rub very hard but do lay against the tank ... Is this normal ?
thank you in advance |
How about some pictures of this.:WWP:
My 782 with dual hyd doesn't have the hoses touching the tank but they're close. Maybe you can loosen them where they connect to the dual valve and manipulate them away from the tank.
here is a pic of the hoses
thoughts??? advice??? |
better pic of the lnes and hoses
better pic
will try to post in a bit with pics
better pic of the hoses and lines
Isn't there a firewall between the tank and everything behind the dash ?
Here is a pic of my 1811 with the tank removed and the firewall still in place. Are those the original lines or did someone replace them?
Iam installing a new to me dual spool valve from a 2072 into my 1811 out of the tractor the new valve and old single spool measure the same except for width ...
