Throttle Shaft Kit...wich one???
There seems to be a lot of throttle shaft kits but I can't figure out which one I need.
This is for the Carter carburator off from my Cub Cadet 100. Do I need more information than that. Thanks as always for the help |
This might help you determine which kit to get:
http://www.kohler-engine-parts.opeen...haft_Guide.pdf |
Excellent, Thank you very much.
This is just what I was looking for. |
Still need some guidance.
What are they referring to when they say 1/2" or 1" carburetor. I have a Carter Model N, #26 carburetor off from a Cub Cadet Model 100. I thought this was a 1" carburetor but the measurements on the chart don't seem to match up. |
I suspect somebody at MTD invented that...I suspect the 1/2" carb means the 7 & 8 hp carb, and the 1" carb refers to the #26 and #30 carbs for the K241-K341 engines.
throttle shaft kit
I can tell you one thing, in the informative posting on this site about the throttle shaft bushing replacement, the writer says DO NOT try to reuse the two small brass screws that hold the plate to the throttle shaft. He has a valid point, they will twist off faster than you can blink an eye. I tried it, learned the hard way. Thats not easy to get back together, least it wasn't for me.
Dave |
This is the number you need:
PN/Kohler # 25 757 16-S |
2 Attachment(s)
This is my throttle shaft...the measurements still don't make sence and it also doesn't look like throttle shafts that I see in other Carter/Kohler throttle shafts.
Thoughts??? Attachment 7619 Attachment 7620 |
Pictures added of throttle shaft...
Something still seams a bit odd...thoughts??
May have to finish disassembly to get exact look at the shaft? Not really sure. I am pretty sure the bushings are 1/4" ID x 7/16" OD.
| All times are GMT -4. The time now is 09:59 AM. |
