| Tractor2nv |
02-01-2011 03:31 PM |
Blade in the way? But want to leave it on?
3 Attachment(s)
Had some solid round stock laying around and got to brain stormin on how to make a front blade "lock" that will stay in the up position.Thus giving me freedom to use the rear lift,loading tractor on a trailer and having no worries of the grandkids dropping the blade while having some seat time out in the field. Do to the fact this 149 has no front PTO,accuator and lever I used the hole in the frame where the accuator slides through. With the lift rod removed and my little fab work this is what I came up with being the tractor is used only for pushing,pulling or towing. I can add a lock at the float area to insure it stays while young operators enjoy the seat time or plan to use myself using the rear lift.
