| young enthusiest |
06-07-2009 10:22 PM |
Creeper problems
Hey guys. I was trying to figure out why my creeper won't go into low, and why it throws oil all over the front end. so I talked to Bryan Baker on Facebook last night, and he said that the roll pin attaching the shift fork to the lever was broken, he also said the rubber seal on the bearing was toast. so I tore it apart this aft, and he was right both times. the PO used tiny wire (like, my braces tiny wire) and wired the fork to the lever. the seal on the bearing had come right out, and was no longer functional. because it wouldn't shift right, the gear that is driven when the tractor is in low, was only engaged about 10%. it is chewed real bad. and the shifter fork is quite bent. more parts to buy. :(
