-   -   CC 100 Rearend Issues (https://www.onlycubcadets.net/forum/showthread.php?t=8855)
mharrison 02-20-2011 06:48 PM
I need some help. i noticed when i went to push my 100 it acts like it's in gear.(feels like neutral, but with the shifter problem i'm not 100% sure) the tires spin opposite ways. the shifter spins completely around. figure the set screw is loose or gone. i'm just trying to figure out what i'm getting myself into.
steve59 02-20-2011 07:14 PM
You need to pull the shifter off and see if the forks are bent/loose/broken/rusty or the shifter itself could have problems. Easy fix.
Merk 02-20-2011 08:28 PM
The gear shifter needs rebuilt if the shifter handle spins comepletely around. It is not hard to do. Check out this topic(s) that is in OCC tech section on how to repair it.
http://www.onlycubcadets.net/forum/s...ead.php?t=4624
http://www.onlycubcadets.net/forum/s...ead.php?t=4625
http://www.onlycubcadets.net/forum/s...ead.php?t=4626
