deck size
2 Attachment(s)
what size deck is this? the outside blades are 10" long and the inside is 19 3/4" long. matt, you said if you had a pic of it you could tell!!! thanks everyone!!!!! jeff
With the blade lengths, It would add up to a 42 inch deck.
Looks identical to the ones I have. |
Have to also remember the gap between blades adds to the length.
Hehehe.. .I think they did like some motorcycle engine makers did and fudge on the actual size, LOL. |
It is a 38in. The two holes on the pulley cover your pulleys are in the one on the inside of the deck it is a 38. If the pulleys greese fitting is on the outside of the mower it is a 42.
:bigeyes: WOW, I really need better glasses, I can't see it that good. Well that is a lesson I just learned. I didn't think about the two grease holes. Thanks MrGitItDone.
So I am still right on the fudging numbers... roflmaooo.. Now I have to go measure the blades on mine just to know what they should measure for a 42. OK my 42 inch deck has a 22 1/4 center blade and 10 3/4 outer blades. :beerchug: |
I had a hard time looking at it too.
sooooooo, we are all in agreement that it is a 38" deck, right? thanks everybody!!! jeff
It is a 38in i checked my deck that is a 38 it is the same blade lenths.
| All times are GMT -4. The time now is 07:27 AM. |
