If it worked before you took it apart, it's probably not the release valves. Did you take the lift system relief valve out?
It's possible that one of the brass lens plates is not sitting flat on the head, Could be sitting up on locating a pin.
And you put the two pins back in to the trunnion/trunnion shaft?
I'm assuming that the wheels aren't turning either.
