Old 03-28-2012, 04:29 PM
billh1963 billh1963 is offline
Default 782D...first maintenance..what should I do?
Oil, air and fuel filter change is obvious; however, what else would you recommend? Hydraulic filter? What else?
Old 03-28-2012, 04:36 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Antifreeze, and make sure to use 15-40 oil
Old 03-28-2012, 05:21 PM
New trans fluid and filter. I would do a complete fuel system clean out with new hoses. Especially cleaning out the fuel tank. Check the hydro trunion and see if there is significant wear that needs to be fixed while the fender pan is off.
Here is link for service manual: http://www.onlycubcadets.net/pdf/772...0Ser%20Man.pdf
Old 03-28-2012, 05:45 PM
Make sure you change both fuel filters. I would use a lubricity/anti-gel additive like Power Service as well.
Old 03-28-2012, 06:35 PM
I was running 15-40 oil in everything. I'm thinking about going back to 30W as the manual says.
Take the tunnel cover off and check the drive line. Diesels are hard on them. Grab the drive shaft (it's best to have the engine turned off) and see if you can move it side to side or up and down. If you can or if the tractor has a lot of vibration at full throttle stop there. I would change it all out for about $150 and not have to worry about it again.
I would also change the transmission fluid and filter.
If you are replacing the fuel filters I would also replace the fuel lines. They are cheap at any auot parts store.
That should be a good start and there will be plenty more to check.
Old 03-28-2012, 09:33 PM
Where is a good source for the filters?
Thanks!
BTW: the drive shaft is new.
Old 03-28-2012, 11:08 PM
I run Wix filters in everything. When you look the parts up on MTD's or PartsTree web site take the KB part number and cross it over to Wix, NAPA or something else. Do not use anything but IH HyTran oil in the rear.
You may have a new drive shaft but there is a brass insert on the motor end, coupler on hydro pump input and 2 rag joints at each end of the shaft. If you run the engine WFO and don't have a lot of vibration on the tunnel cover you are probably okay.
Old 03-29-2012, 08:19 PM
Mountain Heritage's Avatar
Cool
First off, you should be POSTING PICTURES of it!!!
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 03-29-2012, 08:23 PM
Old 03-29-2012, 08:30 PM
Nice, very nice 782D. Ok, now you can continue on with the service questions!
Mike
Ontario, Canada
Beware of the Wife
