Old 05-29-2012, 10:38 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Default 2 bottom plow
Well after getting bored on saturday i decided to start making a 2 bottom pull type plow. So far i have the main frame and mouldboards almost mounted just need to finish weld the frame then drill holes.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 05-29-2012, 10:39 PM
Your off to a good start! Looks like your using 2 8" plows.
Old 05-29-2012, 10:45 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Are you going to make it a sleeve hitch or three point setup?
Old 05-29-2012, 11:15 PM
ihnick's Avatar
ihnick ihnick is offline
awesome. i have the same idea as you. i have 2 small plows but id like to find 2 of the same because mine are pretty different. im gunna make mine sleeve hitch
Nick.
Old 05-30-2012, 07:27 AM
jlampe94's Avatar
Using a 6" david brfadley on the front and a 8" brinly on the rear, not the normal brinly though. Its going to become a trailer plow like a little genius trip plow. Hopefully ill be able to pull it with my 100 narrow front.
Old 05-30-2012, 10:30 AM
mrcubcadet's Avatar
Can't wait to see this done! I have spent a lot of time plowing with a 2x16 Oliver trip plow.
-105___ Tiller
Old 05-30-2012, 11:50 AM
That looks neat! I also can't wait to see the finished product.
Old 05-30-2012, 09:38 PM
WinterHawk77 WinterHawk77 is offline
Nice looking fab job on the frame. I picked up a second 10" Brinly today and plan to do something similar. I want to put two sleeve hitches on an angle off a 3 point hitch mount I made for the Kubota. Then I will have a 2 bottom or can take one off for the cub. I will post pictures as soon as my Speedy Metals order comes in.
Old 06-03-2012, 06:22 PM
fhadderton's Avatar
fhadderton fhadderton is offline
Why did you use moldboards, I have had good luck with the old lister sweeps that I took off of my 8 row cultivator.
