Old 04-12-2009, 01:31 AM
aagitch's Avatar
aagitch aagitch is offline
Default Brinly sleeve hitch adapter
Have any of you ever had the sleeve hitch adapter bend a little bit where the plow hooks to it. It looks bent a little from having it raised up and then maybe the plow bouncing around with all that weight where the hitch pin is. I'm wondering if it'll keep bending more? It is a reproduction adapter with 3/8 thick metal.
Old 04-12-2009, 06:55 AM
A Gitch:
It has not happened to me personally, but I agree, some heavier gauge of steel wouldn't hurt a thing.
Old 04-12-2009, 12:12 PM
Merk Merk is offline
My factory brinly sleeve hitch adapter is bent. I want to add a cross brace as shown in the picture:
I'm not sure how the after market sleeve hitch adapters are made. If they use heat to help in the bend process it can make a weak area. The picture is small-it shows what I want to modify.
Here is what happens when you don't have support on both sides of your sleeve hitch adapter:
The shinny areas was elogated holes.
Old 04-13-2009, 11:12 AM
klejeune's Avatar
klejeune klejeune is offline
Both of the old adapters I have come up with were bent or twisted. I used the fork lift at work to twist them back into shape. I'm sure they'll bend again if used much. Oh well.
I like pie
Old 10-17-2009, 07:55 AM
Mountain Heritage's Avatar
So it sounds like if I make my own of these.....the steel needs to be thicker and braced somehow??
Old 10-17-2009, 10:56 AM
If you use angle iron instead, it is far less likely to bend. Plus, you don't have to make any bends to construct it, either...just 3 straight pieces.
Old 10-19-2009, 06:22 PM
Matt, do you have any pictures of one built like you are saying?
I am about to have to make the sleeve hitch adapter myself if I am to use my plow.... and sure wouldn't mind some hints from folks that have been there already..
In the pics of the aftermarket hitch it shows two shiny new bolts and nuts inserted right next to the tube....are those to tighten up your plow so it won't swing side to side? Would you really want to do that with a land plow??
I know once I actually use it it will all make sense...
Old 10-19-2009, 06:38 PM
Here is a drawing of a fabricated hitch. Seems to be heavier construction as compared to the Brinly.....
Old 10-19-2009, 07:03 PM
Hmm...I don't think so, but I'll have to check. Might take me a few days though, this is gonna be a rough week at school.
I prefer not to use those bolts and let the plow find its own center. That way when you hit something it doesn't jar the tractor quite as bad and bend stuff.
That's the ticket!! I think I can see how one could make it with angle instead of flat stock, too.. Thanks!
