Hey guys on my blower if you look in this pic the sprocket that is on the end connected to the shaft is moving towards the left almost hitting the adjustment bolt how do I get that centered?
You mean the sprocket is moving on the shaft?
![]() How about a little closer pic...... |
I don't think so I grabbed it this morning and it seems to be tight it does not move when running that I can see I took a pic but my dayum computer won't recognize the pic I will try to get it upload today here is the pic
Get it dried off and cleaned up and then post some good pictures we don't have to use X-Ray vision to look at. I'll bet you will find something broken, bent or missing.
Ok here are some more it looks like the PO may have notched the blower housing alittle because of it
This time of year it's not of fun job, I did a replacement gear on mine last season, had the same issue and found a spacer/washer had been missing allowing the assembly to shift over. I suggest pulling it apart and make sure all the drift pins are intact and all your spacers are in place, you can't tell anything from your pics.
Looks like the chain has been jumping around quite a bit to hog that hole out like that. Could be that the bearing on that end of the auger is shot and moved back some. Is it real noisy when operating?
I still don't see what the problem is......
![]() Melt the ice off that thing with a torch or garden hose or something. The problem may literally be all the ice. |
The auger collar bearings were loose last year and I got them reset now the shaft does not move. I guess I just don't know really what to look for to see if I am missing something I just know the sprocket should be it the center and it is not
| Thread Tools | |
| Display Modes | |
