Anyone know just how much voltage an ignition can handle on a K series motor?
I am looking to put my old puller back together and would like to use a small lithium portable power supply for the ignition. I am trying to save some weight to make the #950 class. The one I have puts out about 16volts with no load on it. I know the voltage will drop a little when there is a load on it, but don't expect it to be much lower. I will use a regular battery for starting by using jumpers. Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
I wouldn't give it over 14V, but no longer than you run for a pull, it would probably take a while before it killed the coil. You can always run a ballast resistor to step it down.
Lipo batteries have 3.7v per cell which means a 4cell battery will be 14.8v but when fully charges it will be closer to 16 or 17. Life batteries are only 3.3v per cell which will make a 4 cell only 13.2v and when fully charged will be around 15.2v. life batteries are much safer and wont burst into flames like lipos do.
I always used a small motorcycle battery , ran the fuel pump , ign and vacuum pump . through a weekend of NQS pulling . usually made 4 hooks
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending. |
One of them just puts out barely 12v and the other put out about 16v. The 123A cells wouldn't be a bad way to go, just didn't want to pony up for new cells. I have chargers that will charge anything so maybe. Thanks for the replies all!! Randy
| Thread Tools | |
| Display Modes | |
