Old 11-10-2014, 04:23 PM
FYN409 FYN409 is offline
Default Sediment bowl shut off
The sediment bowl shutoff needle is leaking on several of my cubs. I took one apart and used some graphite packing to replace the old packing. Worked well for about 3 weeks but it appears it did not hold up well to the gasoline and has started to leak even more than before. What do you guys use as packing to replace the old?
-Ryan
Cub Original (1961)
Cub 126 in the process of restoration.
Cub 127
1968 Minneapolis Moline Jetstar 3 w/loader
1965 Minneapolis Moline G1000
1952 Ford 8N w/Loader
1942 Farmall M
1936 Farmall F-12
1931 Rumely 6A
1929 30/50 Rumely Oil Pull
Old 11-10-2014, 04:38 PM
Replacement of the whole assembly. Napa sells them. They're about $25. You'll never get it to stop leaking, and they don't sell repair parts other than the screen and bowl gasket.
Old 11-10-2014, 07:53 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
J-Mech is correct as usual. The part number is 7-02350 for the assembly from Napa. You can google the number and find it online http://www.amazon.com/Prime-Line-7-0.../dp/B002EP9QEA for cheaper than Napa, but my Napa had it in stock and I didn't have to wait or pay shipping.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 11-10-2014, 08:18 PM
captaindemo17 captaindemo17 is offline
I have had great success using small o-rings ! not a leak yet !
Old 11-10-2014, 08:39 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I have 2 cubs that I just put in some orings. I used 2 orings per. I normally just replace it like Jmech said but I had one of my new ones start leaking so I tried this. One year later so far so good.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
Old 11-11-2014, 02:26 PM
The o-ring idea sounds like a worth wile try. As to the NAPA one does this the same part, or just a cheep knock off?
http://www.ebay.com/itm/Cub-Cadet-Or...3D121456865019
Cub Original (1961)
Cub 127
1942 Farmall M
1936 Farmall F-12
1931 Rumely 6A
Old 11-11-2014, 02:50 PM
If I might ask......
Is it really worth ordering something like that on E-bay to save at most $10, when you can just stop by a local parts store and get it? If there is an issue with the one you buy local, I'm sure they will replace it. If there is an issue with the one you get off E-bay..... HASSLE. For the life of me I don't understand why people are so eager to save a couple bucks.
Old 11-11-2014, 03:19 PM
J-Mech you make a good point. Sounds like I will stop by Napa
Cub Original (1961)
Cub 127
1942 Farmall M
1936 Farmall F-12
1931 Rumely 6A
Old 11-11-2014, 03:47 PM
a) I understand. Some don't have the extra money to start with.
b) Some have the money but they want to learn something/try an alternate method.
c) Some people intensely dislike throwing away and usable part without making some attempt to repair it.
d) Many people are not members of the "throwaway" generation and can remember when money was very tight even if it isn't at the moment.
In my experience, repairing a part or substituting a part to see the effects can be viewed as a learning experience, if not an outright cost save. Of course, occasionally, you'll suffer a loss.
There is nothing any more rewarding to me (and others like me) to look at something broken and figure a way to fix it rather than simply replacing.
The old guy in the picture below was somewhat my mentor when I first started turning wrenches. He ran an auto repair shop and later became a Ferguson tractor dealer. A farmer would come in with something broken, no way he'd try to put on a new part if he could fix what was broken.
Old 11-11-2014, 04:18 PM
rwairforce rwairforce is offline
Times sure changed and so did the value of a couple bucks!
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Tags
bowl, gas, packing, sediment
