Old 10-07-2017, 03:02 PM
CMJAnew CMJAnew is offline
Default Trans leak at seal
Another from the, I'm Not A Mechanic And Should NOT Play One In The Driveway:
Tranny leak at the axle seal - left side!
Is this a BIG job? Or is the seal replaced much like an engine seal?
And another thing - I've never been able to move (push) this tractor when it was not running.
Now, for some reason, its relatively easy to move around. Entirely baffled by this.
Old 10-07-2017, 03:32 PM
To change the Axle Seal.....
(A) Drain the Rear End
(B) Pull the Rear End Cover off
(C) Locate the effect axle on the differential
(D) There is a "C" clip at the end of the axle
(E) Remove "C" clip
(F) Pull axle out of axle tube
(G) Remove bad seal
(H) Install new seal
Reverse your steps to restore your rear end.
New Parts:
(a) Rear Cover Gasket
(b) Hydro Filter
(c) Axle Seal
(d) New Hydro fluid - ie: HyTran
Rear end should be be cleaned out and up before reassembly.
Old 10-07-2017, 03:45 PM
What model tractor are you working on?
Edit: I see from your other post that you are playing with an 1882. Pretty much what Roland said but you also need to remove the brakes to pull the axle. This is one I did a few years ago.
http://www.onlycubcadets.net/forum/s...ad.php?t=21261
Old 10-08-2017, 07:10 AM
Thanks for the info guys.
Do you have any insight into the moving and not moving of the tractor mentioned earlier? The why's, what's, and how's of the fact I couldn't, but now can, move it.
Old 10-08-2017, 07:39 AM
That issue would revolve around the Sundstrand Hydro Relief Valves. Pull the relief valves out, and soak them in a cleaning solvent. Once cleaned, blow them out real good. then reinstall.
Report back and advise.
Old 10-08-2017, 07:50 AM
Once this procedure is completed......the tractor "should" or "should not" free roll??
Old 10-08-2017, 09:00 AM
Normally, once the engine is off, and the pump pressure is down (a few seconds), it should be free to roll.
Old 10-08-2017, 10:04 AM
These are the "SU" prefix numbers under the hydrostatic trans section of parts breakdown??
Old 10-08-2017, 12:22 PM
Part numbers with the SU prefix indicates the vendor is Sundstrand.
Old 11-12-2017, 02:06 PM
(E) Remove "C" clip
(G) Remove bad seal
New Parts:
(b) Hydro Filter
(c) Axle Seal
How is the C clip removed? I can't see the holes on the clip to where snap ring pliers would help. Is it a matter of positioning the axle so the holes are available?
