Old 02-25-2013, 10:07 AM
1650noob 1650noob is offline
Default Best methods to revive nuts/bolt?
I was wondering what good methods are for reviving nuts and bolts from rust/dirt/pitting, etc? Also just general good methods to remove such things on any parts? I tried soaking nuts and bolts in apple vinager but it didn't work out too well.
-Nate
Old 02-25-2013, 10:57 AM
Jumper Jumper is offline
Noob: If your bolts have gone ugly due to deep rust and scale the only thing to do is get new one's and paint them up. If your looking to stay with original type bolts, guy's who do allot of cub parting will sell bags of bolt's they pulled off cubs to collectors.(check with our sponsors) Save the vinegar for your french fries, their delicious.
Old 02-26-2013, 01:40 AM
SLS327 SLS327 is offline
Default Removing rust from parts
-Nate
Use a tap and die set to clean out thread holes. If you don't have that, grind three slots in the threads and taper the end of an old bolt and run it in and out of the hole. A wire wheel on a grinder will work for bolts, but wear safety glasses and hold the part securely.
Soak the parts in dark molassas. Expensive, but will remove the rust and give you an orignal surface, shiny part. If the rust has pitted, you can't do much about that. Generally takes about 1-2 weeks soak.
Local hardware stores, bomgaars, lowes, menards generally have selections of new hardware. Take the old one along to compare threads.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 02-26-2013, 04:00 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
what I did for my show cars is , I took my bolts / nuts and brackets to a chromer. they can cad or zinc plate them back to the OEM look. it cost me 35 bucks to do a bolts and nuts from the last car I restored.
Doug
Original , 100 , 125 , 582
Old 02-26-2013, 10:55 AM
Outdoorsben Outdoorsben is offline
When we did the restore of a 74 CJ5 we soaked some small rusted parts in coke and that worked pretty well.
Old 02-26-2013, 01:34 PM
thanks for the tips!
Old 08-22-2013, 07:06 AM
dag1450 dag1450 is offline
I'm in the beginning stages of 2 snow blower restores and have a ton of rusty hardware. I have removed all grease and oil with a soak in paint thinner, then went to a vinegar bath for the rust, my next step before trying to replate them is to clean and shine. Has anyone used a vibratory tumbler like for reloading or deburing ? I have heard they really work well, I have a few on the radar but did not get one yet. Then im not sure on the media to use ether ,I see a lot of walnut shells but didn't know if play sand would also do the trick ? Thanks Dave
Old 08-22-2013, 09:39 AM
PaulS's Avatar
PaulS PaulS is offline
I tried the tumbler/vibrater on a few bolts and left them in there over a day in walnut shell media but it did very little to improve the looks of the bolts. I do use a wire wheel and it seems to do the job in just a minute or two.
Old 08-23-2013, 05:49 AM
Thanks Paul, yea the wire wheel is very tempting at only $10 for the bench grinder, but the thought of handling every nut bolt and washer is overwhelming. Im thinking sand would have to do a better job than the shells but I don't know.Dave
Old 08-23-2013, 07:36 AM
nikster's Avatar
nikster nikster is offline
I've had decent results by;
Soaking the bolts & nuts in parts cleaner for a few hours.
Taking my Dremel & wire wheel to clean the threads.
They are not bright & shiney like new ones but are very usable. On some I use ' School Bus Yellow'. From ace hardware. Or epoxy almond for the white. It all depends how exposed they are? My cubs are NOT museum things. They work & my only concern is to spiffy them up a bit.
On some of the nuts I do re--thread them if they are screwed up.
NIK,
