Hi
My name is Roy I found a few older cubs to work on as a hobby. Most fairly simple with no major issues. Then neighbor gave me his 1811 in pieces. I put it all back together and poof, wa-la, mowed with it 2 years now. In winter, out chains on it plowed snow. I have since bought 2 - 1872 super cubs one with a deck and one with back hoe an bucket. On it back hoe works just needs steering column changed or rebuild. Other one is being a pain when I switch the PTO on it kicks on then as soon as I let go of switch it stops I checked gap it is 17 Thousands, an 3.8 OHMs. On PTO I have cleaned ,most of connection on ends of wires to the point of maybe I may have one hooked up wrong. Any one help me out with a wiring diagram of 1872. Thanks in advance Roy |
As a test, You can power the PTO with 12 volts to make sure the PTO is working Properly. If it is, I would start at the switch, Then start checking safety switches
Hello, reverse switch near the rear under the center cover. Mike
Can you post some pics of your cub?
Thread Tools | |
Display Modes | |
