Old 01-24-2023, 08:40 AM
Graflex45's Avatar
Graflex45 Graflex45 is online now
Default Snowplow blade edge cover
I cant seem to find it on this forum again, or was it on another? There was a tip to cut a slot along a length of iron pipe to make a blade cover for plowing on gravel drives so the blade doesn't dig in.
Anyone remember this post or done something similar on their snow plow? what gauge pipe? does it really work well?
I don't have metalworking equipment so i'll need to draw out a good description and get a welder or someone else fabricate it for me
I got to use the plow on the 1450 the first time yesterday and the driveway at my new house is very rough and in desperate need of regrading and redoing with crushed stone in the spring...
Old 01-24-2023, 08:57 AM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
This one?
https://www.onlycubcadets.net/forum/...highlight=pipe
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 01-24-2023, 08:27 PM
Farmall450's Avatar
Make sure it is in snow mode (unpinned so that it can trip). I have the shoes on mine like a "real" snow plow which help with that a lot.
Old 01-25-2023, 08:54 AM
Graflex45's Avatar
Originally Posted by Radioguy41 View Post
Thanks I hadn't thought of pvc pipe, that makes it cheaper and better in case it bumps into the edge of my concete walkway
Old 01-25-2023, 08:58 AM
Graflex45's Avatar
Yep i have it unpinned so it can flex on the springs if it snags something, what do you mean by the shoes in the real position? if i slide a piece of pvc pipe over it should the shoes not be below the line or should they?
Old 01-27-2023, 10:01 PM
Farmall450's Avatar
Something like this I fabricated for mine.
https://www.amazon.com/Cub-Cadet-703.../dp/B00CSCCJO8
Just like a real snow plow.
