Old 05-16-2014, 07:55 PM
Tony h's Avatar
Tony h Tony h is offline
Default 782 Front Wheel bearings 941-3002 ( 741-3002)
Are the dimensions of these bearing unique to Cubs because the price of a cheesy Flanged Bearing should not be over $10 let alone 2x that price.
At a quick measuring they look like 1" inner and 2.125 outer.
I hate to pop one and and possibly damage a not so bad bearing just to bring it to a Bearing place for alternates.
If I can't fix it , it must not be broken
Old 05-16-2014, 08:06 PM
Maybe this will help.
Old 05-16-2014, 09:26 PM
theunit's Avatar
theunit theunit is offline
Iv been getting the number off the bearing or look in a parts schematic and ordering off of ebay. Usually a lot cheaper.the bearing number should be same dimensions regardless of mfg. Worked
well for me the last couple years ...
2182 super 60"haban deck
IH 782 50"deck
Old 05-17-2014, 12:16 AM
gdheck's Avatar
gdheck gdheck is offline
Napa has them, but I don't remember the exact price.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 05-17-2014, 08:10 AM
Tony h's Avatar
I have an account at NAPA.. Tough to go in there and as to shop their storage room though.
How did you get the part? Did they spend the time to size it for you?
Old 05-19-2014, 02:35 AM
gdheck's Avatar
I just told them that I need a 1" front wheel bearing for a Cub Cadet. We do seem to have an exceptional store here, unlike some.
Old 05-19-2014, 02:37 AM
gdheck's Avatar
Ok, after my other post I looked where I put part numbers like that and found it.
1" wheel bearing Napa is 7-08412 $13.05
the 3/4" bearing is 7-04292 $9.90
Old 05-19-2014, 06:55 AM
Tony h's Avatar
ok, after my other post i looked where i put part numbers like that and found it.
1" wheel bearing napa is 7-08412 $13.05
perfect
thanks
Old 05-20-2014, 01:54 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
I bought some replacements at a local bearing distributor. As they told me the original designed ones were hot rolled to create the flange while the replacements I got from them were machined and more precision made. Still after running a couple of years, I had one of those higher quality bearings shatter the inner race. Was a real bear getting in apart as it swedged itself to the axle shaft while under load. When I finally got it apart, i replaced it with the same bearing but I also added 2 non-flanged bearings (and spacers) to back up the outer flanged bearings and spread the loading out. I have my fingers crossed and after 2 seasons it seems to be holding together fine.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 06-08-2022, 01:31 AM
Farmall450's Avatar
With inflation that front 1" bearing is now over $30
It was actually cheaper to get them on eBay from Minion than NAPA, even after my "discount".
