It won’t idle right, kind of a chug or surging sound. It also won’t run with the choke all the way in. Please help
Sounds like a fuel issue. Try cleaning the carb. Get a temp tank if you need to and gravity feed the carb with fresh gas to eliminate fuel delivery or bad fuel as a problem. I don't think the carbs have any adjustments for fuel/air mixture.
For what it's worth, I've had three Vanguards in different 1641s and they all surged. I may not be a good mechanic, or the Vanguards are finicky, or a combination of both. |
As brudder says sounds like fuel delivery. Not familiar with your engine
but I would start this way. Beginning at the tank work your way to the carb. Pulling all the out feed sides and making sure you have free flowing fuel from the filter and the pump. ( Does this engine have a pump or is it gravity?) If all that is good hook up a gravity fuel source to carb eliminating all fuel supply issues from the tractor. If it still runs lousy you have carb problems. If it runs for you, you know the problem is somewhere prior to the carb. Time to pull the tank and all things before the carb and clean clean clean. It is always a good idea to pull all things fuel related and clean. I am a big fan of eliminating variables one at a time to get to the issue. Ken |
Thread Tools | |
Display Modes | |
