Went to look at a snowthrower today and from search online it looks like a BB36 but measures 42 it came off a 582 how good are they and will it fit my 1914
Tia |
It sounds like it's a QA-42 model - it may be adjustable. The BB-36 was a bolt on; it did not have a quick attach.
Pictures always help - if I don't ask, someone will ![]() Nate
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
i'm kicking myself for not getting any pics but it has the cable for the chute rotate and a quick connect that is not adjustable
Several things are not adding up here...there is no BB42, the nearest thing to that would be a CC42, which would not fit a 582 anyway. A picture is worth a thousand words here, but at any rate, it doesn't matter because it's not going to fit your 1914 anyway. You need a 450 or 364 (or H48).
Ok after searching more, I think it's a Haban H-42. Anyone have info on these? Thanks for the quick replies
Most of the parts are NLA, and it's too small for your 1914. In my previous post, I told you which models will work.
but would it mount on my tractor as snow blowers around here are few and far between
I suppose one could make a Haban H-42 fit with the right amount of fabrication. The H-42 was designed for 482-782 Series of GT Cubs. The H-48 was designed for the SGT 982, 19xx Series of supers.
Click on this link for more information..... Haban
thanks for all the info am gonna pass on the snow thrower and keep looking for the right one
I really have to question why the Haban 42 wouldn't work. As a 582 and a Super are both wide frames. The only problem that I might see is not being able to lower it to the ground all the way. 42 inches will cover the tires track on a super it won't give you much room but is possible.
Josh 1989 SGT 2072 (restored) 60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake Cub 128 with creeper and rear PTO with reverser(next project) IH built 682 and 782 that will combine to make one |
