Old 03-13-2012, 09:15 PM
bocephus1991's Avatar
Default Another primer question
Do any of you or has anyone ever used hardner in their primer? Read online somewhere where they were talking about using hardner in with their primer. I was curious. thanks brian
Brian
Old 03-13-2012, 09:40 PM
gcbailey's Avatar
gcbailey gcbailey is offline
on one type of primer you do, can't remember if it's 1k or 2k... it should say on your primer can what or if you mix it. One of them gets thinned out, and the other gets hardener added. that's speaking of automotive type primer.
Gary
Old 03-13-2012, 09:50 PM
Interesting, considering what hardener does, I never thought of adding it to primer.
Hardener has always made my paint shine more, would that possibly be a negative effect!!??
The next coat might not "bond" as well to a high shine surface.
I love how hard the paint gets with hardener,
this tractor would have looked like without it!!
That is a 4 year old paint job!! With non-automotive, equipment paint.
Old 03-13-2012, 10:16 PM
My primer doesn't say use hardner,just thinner. I had never heard of using hardner with primer either. I thought the same as CADplans it would have the affect of the top coat not adhering to the primer like it should. Thanks guys for the fast response!..Brian
Brian
Old 03-13-2012, 11:12 PM
Some auto paint systems use primer with hardener. PPG 'Shop Line' is one that does this. If it doesn't say to use hardener with the primer, I wouldn't.
Old 03-18-2012, 07:58 PM
toyman's Avatar
toyman toyman is offline
I use epoxy primer and it is a 2 part system, primer and activator(hardener). It creates a chemical bond to the metal and also creates a very durable sub coat for paint. I use PPG omni products.
Original Member #54
Old 03-18-2012, 08:07 PM
Here's what I use.
Old 03-18-2012, 08:21 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
all 2k primers take a hardener. they are a high build primer. the kind you mix a reduser with is just a etching primer/ low build. aka (junk primer) my 0.02
you can use reduser in 2k primers and make a sealer out of it before you paint.
Doug
Original , 100 , 125 , 582
