Old 07-27-2015, 02:38 PM
jimbob200521's Avatar
Default 682/782 mule drive on a Quietline?
As the title suggests, I have a friend who is looking for a mule drive for his Quietline. The only one I have is from a 682/782. Would the newer mule drive play nice with a Quietline?
Personal opinion: I don't see why not, the only difference I know of is the pulleys would be 1/2 instead of 3/8 or whatever the case may be but should still work. Am I right or crazy? Or both?!
-Ryan
Old 07-27-2015, 04:04 PM
Darrell Darrell is offline
I can't remember which one , but the pulleys/shaft are in a different location between the two. One sets farther back and the other forward.
I think the pulleys on an 82 series mule drive set farther forward ?? I tried it once and the PTO belt had a severe angle. I never tried to run it like that , didn't want to try.
Old 07-27-2015, 10:13 PM
SS5150's Avatar
SS5150 SS5150 is offline
I think the 82 series is set forward & don't think it'll work (the pulleys won't sit perpendicular to the PTO like they should). The Q-line/1x8-9 mule is quite a bit smaller and shorter as I recall.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 07-27-2015, 10:17 PM
bocephus1991's Avatar
The mule drive off a 1211 I know will not fit an quietline. It interferes with the latch. I assume the 1211 is like an 82 series.
Brian
Old 07-28-2015, 09:17 AM
Thank you gentlemen, I wasn't 100% sure but seems majority knowledge has out-ruled my guess
-Ryan
Old 07-29-2015, 12:51 AM
I could be wrong, I tried putting the quietline mule drive on the 1211 and it wouldn't fit.
Brian
