Old 03-27-2013, 10:31 PM
bluesman bluesman is offline
Question Tire question
I'm considering 26 inch Deestone super lugs for my 1650 instead of the 23's. What issues if any can I expect to run into and do any of you know of any reason I should stick with the 23's. I'll be using the tractor for plowing and landscaping projects mainly with the front blade.
Old 03-27-2013, 10:41 PM
Grampie Grampie is offline
You Asked, I would stay with the 23 x 10.50 x 12s . 3" taller don't sound like much but it is. You're going to work the tractor, work it with the right size tire. you don't have enough gear to run that taller tire.
Old 03-28-2013, 12:05 AM
macman81's Avatar
macman81 macman81 is offline
everybody i talked to said that 26x12x12 tires are a little too wide for plowing. hard to get down in the furrow like a narrow tire will.
carlisle super lugs are taller and wider than the cheaper ones i have 23 10.50x12 and love them.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 03-28-2013, 10:03 AM
Smile
That's what I was most concerned about. I don't want to run the risk of reducing the tractors pulling power. I guess I'll stay with the 23's. Thanks for the input.
Old 03-28-2013, 10:09 AM
You may want to ask the guys in the puller section, they have been talking about wider rims to get a larger contact patch.
Old 03-28-2013, 10:16 AM
I run taller tires and am VERY happy with them!!
I also have 18x6.50x8 on the front.
This is a GREAT yard machine, handles the blade much better than the 149 I had with stock tires.
The larger front tires really help, when using the blade. It will go over rough terrain much better.
Don't ask me to put a mower deck on it!!
Old 03-28-2013, 09:06 PM
Talking
Frankly I had no technical reason for considering the 26's, I just thought they looked better on the tractor, and I still do. But I realize that they represent a gearing change that might hurt the tractors grunt when it's time to pull my plow or a back blade. I've got wheel weights and will load the tires so I think I'll have enough traction. Always open to more data, though.
Dave
Old 03-29-2013, 07:33 AM
mickb72 mickb72 is offline
Default tires
Dave
Hello, Try to find some comparison pics. I thought there were some posts here or MTF with pics. I think those Deestones 26's are closer to Carlisle 23's than 26's.(undersized) Deestones or Duro's i don't remember. Mike
Old 03-29-2013, 05:18 PM
aagitch's Avatar
aagitch aagitch is offline
I know the Deestones are undersized
Adrian
2072 (789513)
Old 03-30-2013, 07:41 PM
Smile
Yeah, I've read on here several times that the Deestones are smaller. Man, thats a tough decision to make.
