I have a cub cadet model 1605 and it has been getting hard to start.
I believe the issue is with the clutch switch as if I repeatedly lift and press the clutch pedal it will eventually crank and start right up. I need to know where exactly the clutch switch is located.... The tractor is completely dead until it will start cranking and start - no funny noises from the starter, etc. I have tried moving the shift lever a bit to see if the neutral switch the issue - but that has made no difference. thanks in advance for any advice ! |
... follow up :
for future search referencing... clutch switch was not the issue - I cleaned the contacts on the ignition switch and my trusty 1605 cranks immediately every time now .... ! probably a good idea to give all electrical contacts a good cleaning every once in a while ... as I am sure has been posted many a time before ... happy motoring ! |
Glad to hear you got it figured out!
![]() Also Welcome to OCC! |
Welcome to OCC! Glad you got your cub going!
