Old 06-07-2013, 02:43 PM
jmroy's Avatar
jmroy jmroy is offline
Default Tire Tubes
I'm looking for tire tubes for 10.5" wide tires, does anyone have any experience with those cheap multisize tubes on ebay? All the ones I've been seeing have the valve stem in the center of the tube where on the wide wheel the hole is on the outside edge.
Web Developer - Need a website? Contact me.
Old 06-07-2013, 02:48 PM
I buy all my tubes from a local tire shop. When I buy the ones for the rear I use the bolt-on valve stem style. They aren't very expensive. I was thinking about $15 each. Don't try those ebay ones. If the valve stem is in the center, the tube WILL fail.
Old 06-07-2013, 05:39 PM
sawdustdad's Avatar
I've been buying tubes from Miller Tire or Greater Cleveland tire, when I buy the tires.
Old 06-07-2013, 06:22 PM
bolivier's Avatar
bolivier bolivier is offline
PO drilled a hole in the center of the wheel on my 1650. So it now has 2 valve stems. Looks kinda funny...
Old 06-07-2013, 08:04 PM
Do you have to inflate them both, equally!??
