I finally found an attachment I've been searching for (albeit only about 40"): a CAT 0/1 plug aerator. I suspect it's an Agri-Fab, but the ID tag has lost all markings.
Any guesses of the P/N? The only one I see a manual for on their site looks considerably different. Either way, for $20, I can't complain. Slapped 2 tubes in after work today and straightened out the tweaked knives. ![]()
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I just need to find an OEM top link or fabricobble an adapter to fit the 5/8" generic ones and I should be set to put this to work.
Worked pretty good today. It's a bit dicey not getting the 3pt to put down pressure on it (it'll pick the rear end right up).
