I had post a while back about old vs new MTD cubs and someone had mentioned that the newest XT3 was equivalent to my 2155 except for engine HP.
I was looking back at the specs and the do both have the same BDU-10 hydro transmission. Granted the 2155 has the BDU-10L variant, which as far I can tell doesn't have the extra hydraulic ports to power the power steering and deck lift or attachments, but should be the same otherwise. So my question is more about the transmission itself. Is BDU-10 just the hydro pump itself or is it the entire transmission? Is an old BDU-10 the same as the new ones, or is it better/worse? I know everyone says the new stuff is crap and the old stuff is better, but if it's the same hydro what's the difference? |
To my knowledge the BDU10 is just the Hydro. The final drive is designed by Cub Cadet. Many other OEM's purchase a complete transaxle assembly. The XT3's have a diff lock when compared to the older 2000 series. I suspect they are more or less similar, but one would have to dissect parts diagrams or tear down to confirm.
Mark from Minnesota 3165 with CC Snow Blower, Front blade, Sims Cab 3185 with 3pt hitch, it runs now. But not well. 48in and 52in mower decks 2185 with mower from my dad when I have a project for it. Massey Ferguson Model 70 corn planter. CC yard cart |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
