Old 02-26-2014, 08:44 PM
j elliff's Avatar
j elliff j elliff is offline
Default 127
Okay, it seems a few of us are having charging system issues right now. Can someone please help me figure out this.
My charging system wasn't showing that it was charging. I changed the v/r to another that I had (older and had to switch the batt and gen term. to match so that part is correct). Once I hooked the battery back up it was trying to start with the key in the off position.
I'm stumped and although I don't know a lot about this I did check and make sure that it is correctly wired to the v/r. At this point the amp meter is moving back and forth.
any help is appreciated.
thanks, Joe
livin the cub life
Old 02-26-2014, 09:03 PM
Sounds like the normally open tips inside your voltage regulator may be stuck closed/welded and applying battery volts to s/g instead of from the kys start position which sometimes happens. More than likely if it just started happening after you put the other v/r on
Old 02-26-2014, 10:40 PM
I'm pretty sure a wrong V/R can do the same thing.
Old 02-28-2014, 03:38 PM
FFGino FFGino is offline
Default 127 charging system
Hey! That's the same thing that happened to my 128. The tractor was purchased with the motor not turning over (not even with a pry bar against the lugs on the pto clutch!) After getting the engine loose, the starter would turn the engine over without using the key.
After trying all the electrical components EXCEPT the v/r, I rapped on the v/r with a screwdriver handle a few times and the problem quit.
The system charges the battery fine now without any needle bounce of the type that you described.
That may/may not work for you but give it a try. Just don't use a BFH and destroy a possibly good unit. (Is that money I hear breaking?)
FFGino. Happy Cubbing!!
