was there a 3pt lift for a model 86 cub cadet? i haver a awesome 86 been in family since new with all books, but id like to put a lift attachment for a plow on the rear did they ever have one as an add on?
Yep, the 86 used a sleeve hitch. You can hook a plow to it, along with other implements.
Any hitch from a wide frame or Quiet Line Cub Cadet will work.
Wide Frame models are 86-108-109-128-129-149-169. Quiet Line models are 800-1000-1200-1250-1450-1650. |
All right Guys!! Sleeve Hitches and 3-point lifts are not the same thing and some of you know it. Please use the correct terminology. How else are the new guys going to learn??
1) A sleeve Hitch is found on the tongue of a plow or other implement! 2) A Sleeve Hitch Adaptor allows you to hook that implement with a Sleeve Hitch to a Cub Cadet. 3) An IH 3-point lift will allow you to lift that plow (or other implement) for transport. Myron B CCSupplyRoom |
Dale don't forget that the later Quietline hitches used frankenstein bolts and not rod that the 86 uses.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Unless you do like I did and welded the spacers into the frame holes so I could use the same setup as older frames. It's kinda weird,as my 1200 sisn't have the spacers but the other 1200 we parted had a set. They were only a couple months apart too...
Pat Harmon Loganton,Pa 128 Cub Cadet 1200 Cub cadet (Red) LT 1042 Cub Cadet 1200 Cub Cadet 165 Hydro John Deere 1941 John Deere H 1950 David Bradley 5756 1952 David Bradley 57561 Super Power |
AJG: Please read my post above!. Those "frankenstein" bolts are used on the lift arm of the 3-point lift and have nothing to do with any hitch...Puhleeze!!...
Myron B |
