Trying to rebuild my clutch on a 108. For the life of me I can't seem to knock out the spiral pin
I have it soaking in PB Blaster and beating the bugger out of it with not a budge. Can these be drilled out?
Do you have the end of the driveshaft supported good so its not moving around? If you have an air compressor i recommend an air hammer with a roll pin bit. Sometimes there a real bear and you can beat on them forever but they pop right out with the air hammer.
http://www.amazon.com/Wilmar-M668-He...rds=air+hammer Could you also recommend the bit I should look into getting please? http://www.amazon.com/s/?ie=UTF8&key...l_5f8yppar0o_b |
The one you linked to will probably work, you can use a flat hammer bit to get it moving and drive it the rest of the way with a hammer and punch but if you can try to find an air hammer roll pin bit thats a little smaller than the pin so it doesnt get stuck in the driveshaft.
Seriously? I've never seen those. Not even in the Snap-On catalog. Does someone make them?
If Cornwell makes it, Snap-On will too. I'll have to look. I was gonna have a machine shop make me some.....
I never asked snap on if he had them, cornwell was having a deal for a set of 3 so i grabbed them up. They've been well worth the money.
FWIW, since you're looking at China tools anyhow, my HF air hammer has been just fine the 6-8 times I've used it. As a hobbyist the opportunity to use one only pops up every so often.
$9.99: http://www.harborfreight.com/air-imp...kit-92037.html Not sure what is included with that "kit" but mine came with 5 bits and the "pointy" one is plenty to start a stubborn pin, then just finish up with a regular punch and hammer. HF bit collection, $5.99: http://www.harborfreight.com/4-Piece...Set-68277.html Thes are NOT pro quality tools but they're not made of total peanut butter either. |
I guess I have seen things pretty seized up, but not one of those. Seems like a little heat on the shaft would help break it loose. I have not ever used an air hammer for pin removal, on the other hand I have never had one give me that much trouble. Good luck getting it out. TB
