Question on the 1864 after running I idle down and let run for a few moments the shut off. It wants to continue running even with the key in the off position we call it dieseling in my part of the country, any advice on this issue. Also is or was there a gas gauge available for these? thanks in advance..
If I read right the 1864 has a Kohler command engine. Proper shutoff procedure for the command engine is to speed it up to at least 1/2 throttle and then shut it off.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
thanks for the insight, but wont it back fire then some of my other kohlers will do that if they are warm.......I will try and let ya know. thanks much. Btw...is this a common issue with the command motors?
Fuel shut-off solenoid probably isn't working right, or the spring is broken or the rubber tip is bad. Pull it out and have a look. I don't recommend shut down above idle.
http://www.yesterdaystractors.com/cg...rdent&th=50046
- Jason ________________________________ 1872 - Kohler 28hp EFI repower |
J-Mech
Got a pic of the fuel solenoid. ...just getting used to the new technology. Thanks in advance |
I read somewhere, I think on Lawnsite, to never shut down a Command at idle. It can even cause damage to the engine, that is what I read anyway. I have always shutdown my 1863 at a fast idle and it never backfires. Just my experience.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
If that's how you shut down the command it certainly goes against everything that I have learned over the years . With that said I have never owned a command either. I am still getting used to the seat pressure switch. It might get by passes. Lol
