how do you get Expansion plug out of The rear end of a 1572 ?
Not familiar with your model. On my 169 I drilled a hole in the center big enough to put in a sheet metal screw. Grabbed the screw head with pliers and popped it out.
Installed a new one with Permatex anaerobic gasket maker. Partstree part number for mine is 726-0216. It wasn't a tight fit. The only thing holding it in is the Permatex. Hasn't leaked yet though. It was the first and only one I've replaced. Your results may be different. |
How to do it is in the service manual.
http://www.onlycubcadets.net/forum/s...ad.php?t=25397 Basically you drill a hole in it and pop it out with a pry bar. The plugs fit loose until you hit them in the center to expand them. Procedure is also in the manual.
