Old 06-24-2015, 04:29 PM
tommcm tommcm is offline
Default 1440 Safety Circuit Help Please
Stopped running a while back. Found melted, dirty wire from battery to ignition switch. Replaced ignition switch. Also have replaced PTO Switch, Brake Switch and Relay by battery. The Reverse Switch has broken it's mounting connection and is just dangling in open position. Engine will crank and start. Dies when I take my foot off the brake. I can power up PTO with brake on ok. Engine dies when PTO switch is released to the run position. Battery cables all clean, fuse ok. I checked the seat switches and according to my analysis they are OK.
Can anyone offer any suggestions?
Old 06-24-2015, 04:33 PM
First, welcome to OCC......
Did you replace this wire with new...???
Old 06-29-2015, 09:01 AM
Replaced wire. Symptoms still the same.
Old 06-29-2015, 09:37 AM
So, you have the following parts new:
* Ignition Switch
* PTO Switch
* Brake Switch
* Wires in/around the Ignition Switch
Is that correct...??
Next, there are two Seat Switches. One switch (normally open) with BLK & PUR wires, is a safety for the PTO circuit. The other switch (normally closed) with ORG & YEL wires is a safety for the Engine (Magneto) circuit. Thus, a person must be sitting in the seat for the engine to run and to operate the PTO.
AS A TEST........ Remove either the YEL or ORG wire from the seat switch and see if the engine stays running. Report back on your findings.
Old 06-29-2015, 11:11 AM
Sounds like you need a new PTO relay also, if you have to hold the switch up to keep the deck running.
Old 06-29-2015, 04:38 PM
bugeye bugeye is offline
On my 1863, the PTO will release (stop the blades), if the shift lever is put into reverse. Part of the safety not to mow in reverse. Suggest checking the reverse switch next to the shift lever.
Old 06-29-2015, 06:08 PM
It is my understanding, that this is the problem.....!!!!
Old 06-29-2015, 08:11 PM
The Reverse Switch mounting bracket broke off years ago. The switch is just hanging loose dangling behind the dashboard in the open position.
Old 06-29-2015, 08:13 PM
I replaced the relay to the Port side of battery. Not sure what it does, just that it is new. Obviously for lack of smarts, I tend to just start replacing stuff...
Old 06-29-2015, 08:15 PM
* Ignition Switch
* PTO Switch
* Brake Switch
OK. Looking forward to yanking the seat again.. May take me a few days to find the time.
